Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 01-04-2008, 04:24 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Running an open downpipe?
So the other day I bottomed out in my friends driveway. I hit the cat just right to pull it off the downpipe. Didn't break anything just pulled the car right off. The car is ALOT louder and the turbo whines soo much. I'm in the process of putting a straight through pipe in place of the cat (might as well). Anyway, I know N/A cars need back pressure. I'm assuming forced induction cars would too however, I see tons of srt4s and what not cruising with open down pipes too. I also noticed there is an 02 sensor after the cat. The car seems to run fine other than the backfires, rumbles, and having to have the window down all the time. This is not a permanant setup but, i was curious as to what damage I am doing to it driving it like this if any.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 01-04-2008, 04:35 PM
steviek's Avatar
steviek steviek is offline
Re: Running an open downpipe?
nah your fine. the rear o2 does basically jack squat thats what you take out and repace your wideband o2 with. There is a circuit you can build if you want to remove the o2 all together.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 01-04-2008, 05:05 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
The rear o2 just lets the ECU know that the cat is working. Has no control over fuel or timing. Also a turbo car does not need to have any "back pressure", the turbine in the exhaust is enough.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 01-04-2008, 09:56 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Yup, silvr is right, the turbine will do enough but I should point out that you do no need backpressure... you need chasing. Back pressure is a side effect of tubing small enough to maximize chasing, and no matter what people say, back pressure is not a good thing. If you want a pretty interesting read you can find the article about it on tuners.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 01-04-2008, 11:54 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
By chasing I'm assuming you're talking about exhaust velocity?
And yes, you'll be fine running an open downpipe.
95 Talon TSI AWD
97 Eclipse GST
Old 01-05-2008, 01:14 AM
Thor06's Avatar
Jizzed In My Pants
Not exactly, though the two are directly related. When a gas molecule moves, a void follows it. The other gas molecules move in to fill this void. In our case, the exhaust gas moving out of the combustion chamber creates the void behind it effectively sucking the molecule behind it. See? This effect is called chasing. Higher exhaust velocity means bigger void and better chasing, whereas lower velocity means less void and not as good of chasing. Smaller piping means higher velocities but less flow and less flow means higher back pressure. Bigger piping means lower velocities but more flow and less backpressure. Since the exhuaust gas is moving very fast at high RPM's chasing is pretty much negated and its mainly the low/midrange thats affected by chasing or lack thereof. Its a balancing act see, we need to find a happy medium in pipe size so that chasing is maximized at lower RPMs for better midrange, but backpressure is minimized for better power at high RPMs. This is why you cant just slap a 3" exhaust on a NT... it has a lot less backpressure to aide in that top end power, but less chasing so the low/midrange torque is going to suffer. Does this make sense? Sorry if it got a bit scatter brained, I was watching a pretty good episode of CSI while doing this.
Old 01-05-2008, 01:33 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
I run an open downpipe. Apex'i N1 downpipe. No cat or cat back. I've got a custom made turn down bolted to the end of the downpipe though, just to direct the exhaust downward.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 01-05-2008, 01:37 AM
C'mon Dusty, how dumb do ya think I am!? More flow = more velocity = more "chasing". "Chasing" would be dependent on the exhaust velocity. The more velocity that an exhaust system has, the more exhaust gas it will "suck" out of the cylinder because of the pressure differences. So with less velocity you get less pressure differences as well, thus leaving some unburnt "hot" gas in the cylinder, increasing cylinder temps and also creating a somewhat rich mixture, resulting in less power/torque. Now if we really want to get technical, we can go into the theory about exhaust gas temperature changes as they flow from the cylinder through the system, but we won't go there today. Mmkk pumpkin?
95 Talon TSI AWD
97 Eclipse GST
Old 01-05-2008, 02:08 AM
Thor06's Avatar
Jizzed In My Pants
Well, you asked, so I told.
Old 01-05-2008, 03:00 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
there is alot of turbo people around here that use a "Cut-Out". its a Y pipe pritty much one side runs the reg exhaust the other comes off the side right after the Dp and has a screwd on cap over that end that you can put on and remove anytime. put it on for daily driveing take it off for strip or street raceing. pritty effective way i think, that way you also dont get in truble for have a exhaust thats too loud when just driveing.
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 01-06-2008, 04:00 AM
kjewer1 kjewer1 is offline
AF - Advisor
Not entirely relevant, but the RWD does pretty well with this this much backpressure. I don't think the turbine provides much backpressure either.
Well that was a blatant case of a little showing off, I'm a big enough man to admit that, but it still proves the point. Most people with DSMs are in for the HP, not the low RPM driveability and economy.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-06-2008, 03:12 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
ok keven, we get it! yours is bigger!
Old 01-06-2008, 05:59 PM
Thor06's Avatar
Jizzed In My Pants
Old 01-06-2008, 07:38 PM
NateS's Avatar
Lol, I clicked the link expecting to see some of measurement and some numbers. Jealous...
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 01-06-2008, 08:30 PM
AF - Advisor
That big turbo on the left can be yours today for 600 bucks. You know you want it just for your coffee table...
Kevin Jewer
