Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-04-2008, 03:12 PM
ferncreekjeep ferncreekjeep is offline
Front Differential Oil?
'96 LGC, 5.2 V8, Quadtrac
The manual says to use 80/90 gear oil in the front diff. Can I replace with 75/140 synthetic? If so, does it need the additive? On the other hand, the rear calls out 75/140 syn. Does it need an additive?
Thanks
Old 01-04-2008, 07:55 PM
reekor reekor is offline
Re: Front Differential Oil?
75/140 all around is fine. You only need a friction modifier if your diff has a locker. Unless someone installed one in the front no worries there, the rear may or may not have one factory.
Thanks
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
