oxygen sensor
Hi- I own a 2000 pontiac grand prix gt- 3.8 engine. Recently, my gas mileage dropped considerably (12mpg) and I am thinking of changing the oxygen sensor. The "check engine " lite has not come on yet and I was thinking of getting a scope test done , but at the price of the new sensor ($20.00) why spend $50.00 on getting it tested first-just change it. But on my car, there are 2 sensors- one up front and the other after the converter. Do I really need to change them both, or just the front one? Thanks Russell.
Re: oxygen sensor
20.00 for a sensor? oh man, dont put a junky one in stick with quality AC delco!!! To answer your question, no you dont have to change both. The one before the cat converter is the only one that senses the air fuel ratio. The one behind the cat is only there to monitor cat efficiency. If the CEL isnt lit, just leave that one alone.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
oxygen sensor
Hi- Thank you very much for your fast reply. And yes, you are right-it sounded like a scrappy one to me too-except for the fact that I live in Montreal Canada and a genuine one from GM is over $200.00. The one I bought on the internet with a 90 day guaranty,is coming from the U.S. and the seller assured me it was of excellent quality because it was Borg Warner, which I know sells quality products.Thanks again Russell.
Re: oxygen sensor
Even the Cheapo heated o2's are $45 or so. I wouldn't trust a $20 heated o2.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Re: oxygen sensor
i have the same car and wonder how you remove it. i am trying to replace mine but it is tight and hard to get a wrench in there. should i be trying when the manifold is hot?
Re: oxygen sensor
On a different car I had to use an acetylene torch to get the one out to replace it.
Re: oxygen sensor
you guys are trying way too hard....
Go to autozone or advance and rent (or buy) an o2 sensor socket for it. Make live WAY easier. Plus O2 sensors are for the most part all the same size so one socket will probably work for most GM cars. Im gonna buy one here soon. They are cheap enough.
Re: oxygen sensor
Actually I did have the socket and broke it. Bought another socket and then used the acetylene torch to heat up the o2 sensor. Got the sensor out very easy. Made sure to anti-seize compound on the sensor before putting the new sensor back in.
Re: oxygen sensor
Well, i got mine out yesterday no problem. Removing it when the car was hot did the trick. I have the o2 socket also, but they are only good for installation. To remove it it is better to cut the wires and use a regular socket.
Re: oxygen sensor
By the way, i used bosch sensors front and rear. Are they considered junk also as opposed to delco?
Re: oxygen sensor
If it says Bosch on it,it is junk and my father does not trust anything made by Bosch.He has the worst luck anything made by Bosch.If you want to know,Bosch is a non profit company and this is what I heard.Most new O2 sensors have anti seize on the threads already with a plastic cap on the end.Snap On does have an O2 wrench out,I have seen one and it works.It has a breaker bar handle on with the oxygen sensor wrench on it and goes for about $85.00.
Re: oxygen sensor
Hi-Ok, so I listened to you guys and I won't install a Bosch oxygen sensor in my Grand Prix. Up in Canada they are-Believe it or not-$175.00,but I found one on line, AC Delco # afs 109 for $40.00!!! Great Price. Russell.
Re: oxygen sensor
Re: oxygen sensor
Hi- If that 22 mpg is in the city, that's pretty good, but if it's highway - not so good - should be getting about 32-35 mpg highway. When I recieve my sensor, I am going to install it right away. I'll post later on if gas mileage improves and also if it was hard to install. Russell.
Re: oxygen sensor
