Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 01-04-2008, 07:19 AM
guido0136 guido0136 is offline
Increase Milage chips
I've seen on e-bay these aftermarket add-on chips that will increase fuel milage.
Has any one installed one of these, and do they actually work? It just sounds to good to be true.
Thank you,
G.
1993 Pontiac Transsport
Old 01-04-2008, 01:23 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Increase Milage chips
They don't work. Think about it, if a $0.02 resistor would improve horsepower and fuel economy, the manufacturers would readily spend the money to help them meet the fuel economy requirements (CAFE/CARB). These "chips" are typically just simple passive resistors that byplass the intake air temperature sensor to make the PCM think the intake air is a certain temp, so the PCM uses a fuel and timing curve according to the lookup table for that intake air temp. This is probably grossly oversimplified, but basically what happens. The PCM is not being allowed to function as designed and quite often optimized. If the bogus fuel curve causes the engine to run too lean, it can burn valves and pistons. If it runs too rich, then your performance and fuel economy suffers, not to mention the potential damage to the catalytic converters, O2 sensors, and emissions.
Save your money.
-Rod
Old 01-05-2008, 11:05 AM
That's what I thought - I was just looking for ways to improve fuel milage.
Thanks Rod.
Old 01-05-2008, 02:30 PM
shorod's Avatar
SHO No Mo
A tune up and cylinder decarb would be money better spent than money for the "chip."
-Rod
Old 01-05-2008, 08:05 PM
TeamExploder TeamExploder is offline
Send a message via AIM to TeamExploder
Try some seafoam that helps a little bit.
1996 Explorer XLT 4X4 Auto. 4.0 OHV BWM to Fulltime and auto 4X4
1999 Malibu. 2.4L DOHC Auto
2000 Explorer XLT 4X4 Auto 4.0 SOHC
