Old 01-04-2008, 03:54 AM
j-ho_2007 j-ho_2007 is offline
Angry Help Please
I have a 95 3000gt sl 5-speed. my car runs fine for about 5-10 miles and then when i try to accelerate the rpms go up but no acceleration. I have replaced the clutch and flywheel and the problem seemed to go away for about a week but now its back. Any help whould be appriciated.
Old 01-04-2008, 07:10 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Help Please
a little more detail, please. when the rpms go up and u r no longer accelerating, are u driving like normal? does this happen when starting from a stop? does it feel like the clutch is slipping?
did u replace the clutch urself or a did a shop? was the flywheel resurfaced (2-stepped) at this time? how does the clutch pedal feel? u might try to bleed the clutch slave cylinder.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-04-2008, 12:53 PM
Re: Help Please
Yes i am driving like normal. The car runs fine for 5-10 miles and then in all gears when i try and accelerate the rpms rise but i get no acceleration. the car will accelerate like normal til about 3000 rpms but after that the rpms rise way to fast with no acceleration. My clutch and flywheel were replaced at a shop and they said they reserfaced the flywheel.
Old 01-06-2008, 11:32 AM
Linebckr49's Avatar
Re: Help Please
sounds like the clutch. actually, thats the only thing it could be. ho long ago did the shop do this work? ask them if they did a 2-step flywheel resurface. that is the special procedure ou cars require. i would take ur car back and get them to take a look, since they were the last ppl to touch it.
93 3000GT base
Old 01-06-2008, 03:36 PM
Re: Help Please
The shop did the work about a month ago. I am going to take the car up there. Thanks for the help.
