Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-04-2008, 02:25 AM
criprice38 criprice38 is offline
Help removing fenders off 95 caprice
noobie just got my caprice and i wanted to know how to remove the front fenders so i can replace them with new ones which bolts do i remove and what size and type of bolts is it any advice will be usefull thankz
Old 01-04-2008, 07:33 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: Help removing fenders off 95 caprice
Welcome to AF!
Do you have the new fender you wan to put on the car? If so, you can look at the bolt holes on the new fender and match them up to the one that is on the car to get an idea of which ones need to be removed. That's what I've done in the past when presented with that problem. Also keep in mind some of the bolts may give you a hard time removing and may snap off if too much pressure is used on the wrench, so be prepared if that should occur. That has happened to me in the past with the older vehicles, I don't know how it is on post '90 vehicles as I haven't taken any body panels off of them.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 01-04-2008, 07:40 PM
yea thanks for the advice, il be getting new fenders soon, is it true il have to remove doors first before i can take fender off? reason is previous owner swerved into sidewall and the whole fender got dented in plus the wall where bolts are screwed into is dent also so il have to hammer it back into place
