Old 01-04-2008, 02:23 AM
KrnAznEP KrnAznEP is offline
Hardline trouble
Yeah i stripped like two hardlines even with a flare nut and line wrench. Now im worried i have to get a mechanic to fix my problem. I was trying to change the Brake lines as well as the Clutch hose. I was maybe thinking of buying a locking plier??? any suggestions? Thanks
Old 01-04-2008, 07:17 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Hardline trouble
yes, locking pliers or vise grip pliers work well. also spray some rust penitrant (pb blaster works great) on the connection. and if u feel it starting to strip, stop. also, if ur using locking pliers, use two pair to hold the other end fixed as u try to break it loose. and remember: righty tighty, lefty loosey. good luck.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 01-07-2008, 10:25 PM
thank you!
