Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 01-03-2008, 09:29 PM
kyyooper kyyooper is offline
97 tbird wont start when cold
97 t bird 4.6 will not start below 30 degrees.have put in new coolent sensors and air temp sensor in the air box also i just changed the o2 sensors and the fuel pressure is 48
Old 12-14-2010, 10:49 AM
autogas01 autogas01 is offline
Re: 97 tbird wont start when cold
my 97 is not starting well in cold weather either.
a 4.6, the car runs perfect once warmed up but the issue is when cold,when i go to start it in the mornings i have to hold my foot on the gas to keep it runnin,id say about 2k rpm's, and during the time im helping it idle you can feel the motor running bad like its running off 5-or 6 cyl,real bad miss, and it also makes popping noises in the intake, once it gets completely warmed up it runs great, once running i have no issues,car runs great and has lots of power, i've cleaned, tested and/or replaced the following in the past few months hoping to clear the problem- TPS, IAC, MAF , plugs & wires, fuel filter, AIRFILTER, cleaned the TB, PVC, also did sea foam, after all this it still does the same thing when cold.
Old 02-06-2011, 09:20 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Is your check engine light on? Have you ever had any problems with your cats?
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 02-07-2011, 02:12 PM
danielsatur danielsatur is offline
The symptoms of a dirty, or bad Massive Air Flow (MAF/IAT) sensor is a cold hard start.
