Old 01-03-2008, 06:35 PM
jeep_cj4x4's Avatar
jeep_cj4x4 jeep_cj4x4 is offline
Send a message via MSN to jeep_cj4x4 Send a message via Yahoo to jeep_cj4x4
gear lubes
I'm pretty sure I know the answer to this but figured I'd ask anyway.....
Ok, I just picked up my truck after having an Auburn limited slip and new gears installed. I had taken in my own oil and noticed they had charged me for oil. I had my own.... They said that you cant use synthetic with Auburn's at all, "it says it in the manual".... Sure enough, it says they used a "high quality NON-synthetic and a friction additive" to do their testing with. It says "to avoid differential clutch chatter and for optimum performance, use the oil and additive described above. Use of other additive and oil types may cause differential clutch chatter."
I figured, let them put in their shop lube of choice since I'll be changing it after the break-in anyway but when I do.... Can I go ahead an use my SYNTHETIC of choice with an Auburn diff?
2004.5 Silverado 2500HD 4X4, LLY, Banks 6-gun/speed brake/intake, Dual bypass oil filter, 4" exhaust, 265/75R16 Bridgestone Dueler A/T Revo2, AirLift airbags, AMSOIL in everything!
84k miles/30NOV11
Yeasu 857D/ATAS-120A - "When all else fails..."
Old 01-03-2008, 07:29 PM
j cAT j cAT is offline
Re: gear lubes
limited slip diff uses 80-90wt with 4oz friction modifier added some who have used synthetic have had slippage /chatter and went back to recommended fluid.as i'm sure you know this type of diff requires fluid changes often. like 20-30,000mi if your working it hard............
Old 01-03-2008, 07:46 PM
rjeffery rjeffery is offline
Re: gear lubes
Use what the manufacturer reccommends, especially if your gear set came with a warrenty.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 01-13-2008, 07:29 PM
jeep_cj4x4's Avatar
Re: gear lubes
Originally Posted by j cAT
... this type of diff requires fluid changes often. like 20-30,000mi if your working it hard............
Thanks for the inputs....
I change my gear lube at about 1/yr or 15k anyway (just because) so that wont be an issue....
84k miles/30NOV11
