Old 01-03-2008, 05:10 PM
alero03 alero03 is offline
how to change ingnition switch
whats the easist way to change an ing switch in a 03 alero 2.2(in dash type)
Old 01-03-2008, 05:16 PM
The_Mechanic_33's Avatar
The_Mechanic_33 The_Mechanic_33 is offline
Re: how to change ingnition switch
Does the key fit and turn in cylinder?
Old 01-03-2008, 05:18 PM
yup
Old 01-03-2008, 05:23 PM
Pull radio,remove ignition bezel with small screwdriver.
Put key in ignition turn to on position and through radio access use a small screwdriver or drill bit to depress pin in cylinder and use key in aid to pull cylinder out.
Old 01-03-2008, 05:31 PM
does the radio need ''keys'' like a ford does???i havent had achance to look at it yet ive been to frickin busy i just wanna know if i will run into any problems when i do get a chance to work on it...thanks
Old 01-03-2008, 05:34 PM
nope
Old 01-03-2008, 05:46 PM
But relearn procedure must be done.
1- ign on,engine off
2- attempt to start engine then release key to on position
3- observe security light,should be on,after 10 min light will go off
4- turn ignition off wait 5 secs
5- vechicle now redy to learn passcode
6- try to start if it starts,clear codes,if not redo 1-6
Old 01-03-2008, 09:40 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Might check this link out(its for the grand am , exaclty the same part and procedure) it's a little more involved then whats described above.
http://www.automotiveforums.com/vbul...d.php?t=715987
Can be tricky getting the cylinder to release and the cable/wire connectors.
Hope that helps
1999 Grand Am SS 3.4 OHV
Old 01-03-2008, 10:41 PM
thanks guys hopfully i will get a chance to dig into that on friday if its not too cold
