Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 01-03-2008, 02:01 PM
ntwalker ntwalker is offline
reading diagnostic codes
I'm attempting to read the daignostic codes on my 92 T/C. The manual I have is vague in describing the pin numbers on the diag connecter. The plug has two rows of pins, the top row has two pins and the bottom has 4 pins. Does anyone know how they are numbered? I need to identify pin 2 and pin 4. The connector is something like this:
XX
XXXX
If anyone has any suggestions to simplify the process, please let me know.
Thanks to all,
Old 01-03-2008, 04:34 PM
The_Mechanic_33's Avatar
The_Mechanic_33 The_Mechanic_33 is offline
Re: reading diagnostic codes
Try autozone they read for free
Old 01-03-2008, 05:08 PM
reekor reekor is offline
They don't read pre OBDII systems..............
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 01-03-2008, 05:12 PM
XX
XXXX
Thanks to all,
Old 01-04-2008, 07:51 AM
The diagram is very clear, thanks. The book says to read the codes first without the negine running and then with the engine running. I will try again this weekend and let you know the results.
Old 01-15-2008, 01:30 PM
Because the check engine light was on, I was reading the codes. I got as far as the key on engine off. I turned the key off and the Check Engine Light went off. I drove the car about a mile and parked it, it hasn't came on again.
