Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-03-2008, 11:40 AM
black91rs black91rs is offline
I Need Help With 95 Rodeo
I need help for this one... My rodeo doesnt want to start. It cranks but thats all it does. The problem started when about a week ago it started to bog down when i tried to acclerate. I would acclerate more and it would go away and the check engine light would come on. Once that would happen the it would run fine. I ran like that for a couple of days. One night it would just not start. I checked all the fuses and they are all fine. I am really stuck on this. I need help.
Old 01-03-2008, 12:44 PM
andrew_j's Avatar
andrew_j andrew_j is offline
Re: I Need Help With 95 Rodeo
what engine is it? have you had your codes read? that may tell you more. you say it won't start, is it sparking or just turning over....
I suggest you buy a code reader from autozone or northern tool (approx. $60)or something and find out why you have the check engine light first. I believe autozone does lend a tool so you could possibly try that.
1996 Honda Passport EX 4x4
On it's way to 161k FOR SALE!!!!
2000 Acuera Integra LS 5 speed
Old 01-03-2008, 12:54 PM
95.5 Rodeo's Avatar
95.5 Rodeo 95.5 Rodeo is offline
Like Andrew said, we need more information about the symptoms and what engine your Rodeo has.
Any Rodeo earlier than 1996 is OBD I and is not compatible with the newer OBD II code readers.
You need to jump the ALDL connector and count the flashes on the check engine light.
There are plenty of posts here on how to do it, just search.
Get back to us after you retreive the code(s).
Good Luck,
Dale
Old 01-03-2008, 05:22 PM
trooperbc's Avatar
trooperbc trooperbc is offline
with those symptoms it could be a ton of things. but here's my gut reaction. it's the fuel pump system, probably the fuel pump itself, but possibly as simple as the fuel pump relay (swap with another relay in the box that is the same for a simple rulein/ruleout). AND/OR the connectors at the fuel pump may have come loose OR the wire/connector junction has become corroded or dislodged.
first check: when you turn the key on, without starting, do you hear the fuel pump run for 2-3seconds?
it would be helpful to read the CEL code, but i'm *guessing* it was set as a byproduct of poor fuel delivery.
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 01-03-2008, 07:01 PM
Exclamation Re: I Need Help With 95 Rodeo
The engine is a v6 3.2. It has no check engine light on as of right now. It has gas going through and it has spark. it cranks but wont start. also i hear the fuel pump come on when i turn the key.
Old 01-04-2008, 02:42 AM
trooperbc's Avatar
the codes are stored, so even if the light is not currently on (well it doesn't run so how do you know), anyway, you should read the stored code by jumpering the diagnostic connector and reading the flashes. do you know how to do that?
it'd be the place to start....
//bc
Old 01-04-2008, 10:36 AM
no i dont know how to do that. i'll do a search to see if i can find how to do that.
Old 01-04-2008, 10:49 AM
95.5 Rodeo's Avatar
Just curious-
How many miles are on the vehicle?
Have you done a compression test?
Has the timing belt ever been replaced?
Good Luck,
Dale
Old 01-04-2008, 11:12 AM
no i havent done a compression test, it has 143,302 miles on it and i have never replaced the timing belt
Old 01-04-2008, 07:24 PM
amigo-2k amigo-2k is offline
Isuzu Guy
It might be worth your time to remove one of the timing belt covers to see if the belt is still on.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 03-18-2008, 03:26 AM
poo 95 rodeo poo 95 rodeo is offline
if you have the 3.2 with the 3 coil packs on front, try changing out the far right one. it sound like mine a while back i wont say what i went throught to find that out but for all that money it took a $20.00 part .hope it helps
