Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 01-03-2008, 11:27 AM
The_Mechanic_33's Avatar
The_Mechanic_33 The_Mechanic_33 is offline
Question No Start spark an fuel ok
2000 4.7 liter
Spark=ok,fuel=ok(50 psi)volume good too,injector pulse=ok,no codes(set code so I could check if scanner would read and alls fine with comunication).
Sync signal ok.
new plugs; engine cranks fine and floods just wont start.
Any new avenues I'm stumped?
Feel free to ask questions I might have some answers as I have performed other tests too.
P.s. I have Modis (snap-on) so I can also perform tests per your suggestions.
Old 01-04-2008, 09:57 AM
Re: No Start spark an fuel ok
compression is 125 except on 4&8 which is 90psi.
Old 01-04-2008, 02:44 PM
Benzman Benzman is offline
Starved for air?!?
Also, the computer is capable of shutting down the fuel pump for security purposes. But this usually shows up as car starts and runs for a few seconds until after the 3rd attempt. Then it won't even try to fire.
Old 01-05-2008, 01:24 PM
fuel pump is fine,as is the asd relay and circuit,and map,ect,tps,iac,grounds. Thinking computer is bad.
Thanks though.
Customer can't afford any more diagnostic time so truck will be gone soon.
Old 10-30-2018, 08:47 AM
clutch492 clutch492 is offline
ASE Master Tech
I have seen this myself. The ignition coil is weak. You will see spark, but it will be a white color spark. Don't be fooled. It is not strong enough to fire, under compression pressures. New coil fixes this. You will then have a nice snap and blue spark. Good luck.
