Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-03-2008, 10:59 AM
jdmcivic12 jdmcivic12 is offline
car won't fire
well, my car won't start, it has a new altenator, new spark plugs, new serpentine, and altenator belt. IT WILL crank over but won't fire. any ideas, or someone close please help
Old 01-03-2008, 11:07 AM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: car won't fire
Is your fuel pump running?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 01-03-2008, 11:38 AM
Re: car won't fire
im not sure, im kinda new to the whole car mechanic thing, what would be the easiest way to tell if it is or isn't?
Old 01-03-2008, 02:57 PM
JoeShmoe's Avatar
Re: car won't fire
Turn the key to the on position and listen under the rear seat and pay attention. If you can hear current running thru there than you would have a good pump.
Old 01-03-2008, 05:16 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: car won't fire
What trim? If it's an RS/GS/ESI and you installed the alternator yourself, there's a good chance you wrecked the cranks position sensor, which could explain why it's not starting.
95 Talon TSI AWD
97 Eclipse GST
Old 01-03-2008, 10:14 PM
JoeShmoe's Avatar
Re: car won't fire
Where is that at garret?
Old 01-03-2008, 10:44 PM
Re: car won't fire
Directly above the oil filter, like 3" up or so.
95 Talon TSI AWD
97 Eclipse GST
Old 01-04-2008, 12:55 PM
Re: car won't fire
we did do the altenator ourselves, but the car wouldn't start before that. on the eclipse, where do you find the spot to check fuel pressure. i have a gauge but can't find where to use it.
Old 01-04-2008, 01:11 PM
Re: car won't fire
IIRC, it's either on the top of the fuel rail or somewhere on the end, but don't quote me on that.
95 Talon TSI AWD
97 Eclipse GST
Old 01-04-2008, 01:40 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: car won't fire
It's on the top, I believe closer to the inlet. Sits straight up. May have to move the wire looms out of the way to see it.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 01-05-2008, 06:31 PM
Re: car won't fire
i heard nothing under my seat when i turned it on. when i tested the fuel injection pressure, i was getting no pressure at all, and it wouldn't read anything at all
Old 01-06-2008, 12:45 AM
Re: car won't fire
Check your Haynes manual for a fuel pump test procedure.
95 Talon TSI AWD
97 Eclipse GST
