Pushy Pushy
Driving down the road in my 97 silverado I can take my foot off the gas and maintain my speed for miles. For some reason the engine wont slow down.
When I apply the brakes the engine rpm's decrease (under load), but when I approach a stop sign (in the snow) my front tires stop but my back tires are still pushing. It has caused some hairy situations trying to get stopped. The only way I can stop is to drop the transmission into neutral at which point the rpm's go up to about 20k. I dont know how to adjust the engine idle, but I have lubricated the throttle linkage. I currently have a check engine message on the dash but no way of knowing what the codes are if I even knew how to check them. Is there a cheap code tool of some kind out there? Is there any place I can get the code information? Help guys, I'm slipping. |
Re: Pushy Pushy
That sounds a little scary. There is no idle adjustment, it is all controlled by the computer. A lot of auto parts stores(autozone is one I know for sure) will read codes for free. That will give you a place to start. As far as cheap code readers go, you can pick one up at walmart. All it will do is read codes, if you want a scan tool it will cost you some big bucks.
2009 Silverado 1500 2002 Camaro Z28(rebuilder) 2005 Yamaha GP1300R |
Re: Pushy Pushy
If your back tires are still pushing after you apply the brakes you may want to check if the self adjusters are adjusting your back brakes. Is the brake pedal up at the top or is there some travel before the brakes start applying. An excess amount of travel may mean your back brakes aren't adjusted up all the way. The low brake pedal can be an indicator for some other problems too, but look at your back brakes first.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck) 1968 Pontiac Parisienne (rust free survivor) 1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck) 1989 Chevrolet K3500 RC/LB (454 & single rear wheels) 1991 Chevrolet Caprice Classic (police cruiser clone) 1992 Chevrolet K2500 EC/SB (almost rust free daily driver) 1998 GMC C1500 EC/SB |
Re: Pushy Pushy
First of all, you don't have a rear brake problem, you will if this continues, but it isn't your problem. Your engine idle is not slowing when you take your foot off of the accelerator, like it should. I've found most auto parts stores will read your check engine code for free, especially AutoZone, I've used them in the past.
I had this happen on a 91 I used to have, the Throttle Position Sensor went out. Relatively cheap and easy to replace on the side of the throttle body, opposite the linkage. I would get the code checked, that would be a good start.
"Yes I have a truck and No I won't help you move your stuff..." 2008 Kawasaki KLR650 2500mi (fairweather commuter) 1992 C1500 Silverado 235,000mi (daily, not so much anymore, driver) 1999 Venture 120,000mi (moms vacation bus) 1989 Dodge Ramcharger SOLD, Yee-Freak'in-Haw |
Re: Pushy Pushy
Thanks Coconut, I thought it might be a sensor or something.
I'm gonna get the codes read and see what that says the problem is. I'll let you guys know what happened. Thanks for your help...all of you. |
