Old 01-03-2008, 05:30 AM
phiscott phiscott is offline
Mis-Fire
Allright guys and girls, I've got a '97 4-dr, 2.2L Cavy with a "92 2.2L Corsica motor in it. I put it in last June, worked fine, until now.
I'm thinking it's the coil pack, but I'm not a hundred percent sure, so here's the deal...
My number 3 cyclinder is not firing BUT, I have spark coming through the all the wires (including cylinder 3), I checked with a tester. But the spark is not passing through the plug. So obviously I changed the plug last night in the Crappy Tire parking lot, same thing. I got home and checked for fire again, and exact same thing, so I just unplugged the injector so I don't screw my motor.
Would this be from a weak module on the coil pack? And I thought that if the coil pack was bad, going or gone it would have 2 dead cylinders instaed of just one? So should I change the pack, or is it something easy that I'm over looking?
Thanks
Old 01-03-2008, 12:05 PM
muff34 muff34 is offline
Re: Mis-Fire
so you have a tester which you put inline and it shows spark but you have none you say ........mmmmmmmm weird .how are the plug wires ?
Life Is A Highway ,Enjoy The Ride
