Old 01-03-2008, 03:22 AM
Furbal68 Furbal68 is offline
oil leak on 1993 accord
I have a small oil leak between the oilfilter base and the block how do I fix it?Are they a gasket there?
Old 01-03-2008, 10:03 AM
mattham912 mattham912 is offline
Re: oil leak on 1993 accord
yes...there is a gasket that is supposed to be there.....you may want to redo an oil change, and check to make sure a previous gasket wasnt stuck, or that the new oil filter has a gasket on it.
Old 01-03-2008, 11:46 AM
somick's Avatar
somick somick is offline
You do not even need to redo oil change. Unscrew the oil filter. Make sure there is no old gasket stuck.
The gasket on your oil filter or filter itself is most likely bad. Replace the oil filter. Top off your oil, since you will loose some with the old filter.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
