Go Back   Automotive Forums Car Chat > Mitsubishi > General Discussion
Old 01-02-2008, 03:07 PM
expo95 expo95 is offline
Ignition Coil, Crankshaft Position Sensor
Does anybody know where they are located? The car is EXPO 1995.
There is no spark in the car. I will check these 2 parts.
Old 04-03-2008, 11:11 PM
mxmikie mxmikie is offline
Re: Ignition Coil, Crankshaft Position Sensor
coil is on the intake manifold the crank sensor is in the dist
Old 07-07-2008, 05:59 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
remove your distributor cap and spray it with ether or ethanol. removes water. those cars are notorious about cap gaskets being very "leaky" to vapors/humidity, and then it won't start, period. also, inside the distributor, underneath the rotor housing, there's a capacitor (condensor?), that goes bad often. that'll kill the spark either.
Old 11-26-2008, 09:35 AM
ether or ethanol will eat the electrics in the distributor
