| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
I think I posted this before, but my tranny makes noise when running. It mostly does it when cold, and goes away when the clutch is pushed in. Did some searching and came to the conclusion of TOB.
NOW, that tranny/clutch is brand new as of 5/21/07. The trans and work I believe had a 6 month warranty on it, and plus since I was in an accident since then, I don't the they would even do the warranty work because they'd probably blame it on the accident. Is there anyway to get to the TOB without dropping the whole tranny, like disconnecting it from the block and its right there? It's getting annoying and apparently it's caused by the inner grease stuff drying up. What should I do here?
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
Re: Throw Out Bearing
To replace the TOB you have to drop the whole tranny.
What clutch did you put in the car? I get a rattling noise from my tranny also, but its because of the clutch I put in it. It doesn't have a pre-dampened hub and so you hear a little bit of gear rattle at idle. When you push the clutch in it goe away because the tranny isin't spinning any more. Not saying this is your problem but if you have an aftermarket clutch its possible.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
It's also a general thing to go with OEM TOBs even among the ones with 4G63's. ACT apparently provides an OEM one. I have both in front of me and will be putting the OEM one in. I have heard to many incidences of even the updated plastic sleeved one failing.
Tim 1990 Talon AWD 2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink, PTE SCM5031
Yes I am positive its the clutch. Happens to almost all the cars we have put a clutch in. Any clutch above stock you will get a little bit of gear rattle. This is with a zoom clutch.
I get the same but goes away soon after everything heats up a bit.
2004 Mazda 6i 1997 Tahoe |
