Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 01-02-2008, 12:49 PM
smdtherock smdtherock is offline
question about tires for 96 dodge dakota
I am trying to buy some new winter tires for my truck, my size for my truck is 215/75/r-15 and i'm trying to buy 2 winter tires but they are 215/70/r-15 does the 75-70 difference make it impossible to do this?
Old 01-02-2008, 01:45 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: question about tires for 96 dodge dakota
The 70-series tire will be a lower aspect ratio tire than your current 75-series (i.e. the sidewall will be smaller). The aspect ratio number is the percentage of the tread width (e.g., for your 215/75R-15, your treadwidth is 215 millimeters and the sidewall height from the rim would be 0.75 x 215 = 161 mm.
This change from 75 to 70 will result in a change in the effective diameter of the tire/wheel (sidewall reduced to 151 mm), thus the rolling circumference, and thus throwing off your speedometer. If you have a 4wd, and must replace tires, you should get all 4 the same size and recalibrate the speedo if you go with the 70-series tires.
If you wish, you could "plus-size" your tires, where you offset the reduction in sidewall loss by increasing tire width, resulting in a tire that has the same overall circumference. A tire dealer would be able to help you with this, but larger, fatter tires are generally more expensive.
Stick with your original size if you want 2 tires on the cheap.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-04-2008, 01:04 PM
master hec0's Avatar
master hec0 master hec0 is offline
Send a message via MSN to master hec0
i was previously told that you cant recalibrate speedos on dodge dakotas but how would i do this on a 2000 dodge dakota i have 33 inch tires on my truck and my speedo is about 23km too slow
Crop circles are Chuck Norris way of telling the world that sometimes corn needs to lie the fuck down
The Great Wall of China was originally created to keep Chuck Norris out It failed miserably
A Handicapped parking sign does not signify that this spot is for handicapped people. It is actually in fact a warning that the spot belongs to Chuck Norris and that you will be handicapped if you park there
When the Boogeyman goes to sleep every night he checks his closet for Chuck Norris
Old 01-04-2008, 01:30 PM
jdmccright's Avatar
The RustBuster
Superlift sells a TruSpeed recalibration box for 1992 - 2003 Dak models (Model# 33002).
http://superlift.com/accessories/truspeed.asp
I don't know how it works, but found this thread that claims success:
http://www.dodgedakotas.com/boards/off/516.html
Quick Internet searches show it costing around $180-$200. Steep, but should fix speedo as well as shifting problems resulting in better fuel economy.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
