Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-02-2008, 12:03 PM
waterskier_69 waterskier_69 is offline
91 Firebird 305 TBI sputtering
I have a 91 firebird 305 TBI with about 167,000 miles. I am the original owner. A couple of months ago, I started having this problem. It seems to run OK when first started cold, but as it warms up I can feel it "missing" or hesitating under light acceleration. After about 15 minutes when it is fully warm, it will run very badly, missing and sputtering whether accelerating or idling in gear. After 5 or 10 minutes of this it then improves somewhat, sometimes the problem will go away, or when I have to stop and idle again it may or may not continue. After the weather turns bad in November I don't drive it much, maybe once a week or two. It is in a garage when not being driven. I replaced the fuel filter and ran heet through the gas. I took it to the dealer, they found no obvious problems or computer codes (of course), but replaced the cap and rotor because they said there was some corrosion. This did NOT fix the problem. As you can understand I do not want to throw more money at repairs that do not fix the problem. Any ideas?
Old 01-09-2008, 08:16 PM
Blaiser17 Blaiser17 is offline
Send a message via AIM to Blaiser17
Re: 91 Firebird 305 TBI sputtering
Have you checked the fuel pump or pressure?
1999 Chevy Monte Carlo 3.1L
1991 Chevy Camaro 3.1L
1981 Chevy Camaro z28 383 Stroker
2000 Mercury Cougar v6
Old 01-10-2008, 08:21 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
If the fuel pressure check out have the ICM (ignition control modulu) tested several times
Old 01-10-2008, 11:50 AM
I thought when a fuel pump quit it just quits and does not run. Is this different for an electric fuel pump as opposed to mechanical?
Someone else told me it could be a bad spark plug wire or hairline crack in a spark plug that behaves different at different engine temps. Does this sound likely?
Why would a problem with the ICM not turn up any computer codes?
Old 01-10-2008, 11:57 AM
wrightz28's Avatar
Not neccessarily saying it's a fuel pump failure, but a pressure check, especially a running check when the problem occurs can eliminate it from the picture.
Cracked plug, it should run like poo at all times.
There are a few ignition components that can cause these symptoms, BUT, anytime I hear "sputters" I tend to lean toward eliminating the fuel system.
Old 01-25-2008, 09:13 AM
Problem found. Bad spark plug wire. Thanks for all the tips.
Old 01-25-2008, 10:55 AM
wrightz28's Avatar
cool beans, love it when it's something 'easy', thanks for the outcome
