Old 01-01-2008, 07:54 PM
rlsc98 rlsc98 is offline
crank. position sensor question.
my truck developed a random misfire over the past 6 months, really bad @ times and could not connect any set of circumstances to the misfire. I thought I would check the CPS ,so I took it offand found what looked to be a rubbing mark on the surface of the CPS. What could cause this?? A warped trigger wheel? If moisture builds up on the wheel would it cause a misfirecondition??
thanks in advance,
Ron
Old 01-02-2008, 03:11 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: crank. position sensor question.
A warped ring is a possibility. Dirt, sand, gravel, etc. could also cause the rubing. There is very little clearance between the ring and sensor.
I would not expect moisture to cause an eroneous sensor reading, as it is magnetic, and water shouldn't affect a magnetic field. If the water were to freeze on the ring, this could also be a source of the marks.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-02-2008, 03:12 PM
maxwedge maxwedge is online now
A990 racer
I'd start with posting year and engine!
Old 01-02-2008, 04:48 PM
So sorry thought I did that . Its a 1997 C1500 2WD Vortec 5.0,with a 137,000 miles.
Thanks.
