Backflushing a heater core
I need to back flush the heater core on my 97 Taurus. I have a couple of questions:
1) is the line on top (as it goes into the heater core) the in, or is it the one on the bottom? 2) I am having trouble disconnecting the hoses. I'm thinking I can connect a tee (the ones you find in the prestone radiator flush kits) to each side of the heater core. That would give me something to hook the hose up to, and also an easy way to flush it again later. Will this work, or will the coolant go the long way around (through the engine and resevoir) instead of through the core? Any other advise in getting this done would be appreciated. I figure If I flush it and I don't get my heat back I have to pull the water pump. |
Re: Backflushing a heater core
I need to correct myself here, as I incorrectly stated the order in which the heater core gets its heated water. I should have said typically on an engine, the heater core gets its water from the engine near the thermastat and upper radiator hose, it passes through the core and returns to the engine at the water pump. So trace a heater hose that goes to the front left side of the engine from the fire wall. It becomes a shiny pipe before it connects to the front of the engine. The right hose at the firewall goes to the back side of the engine, connecting next to the thermastat and upper radiator hose. From there, your on your on, but truthfully, they aren't built one way only unless they have a valve on it which most don't have. But I guess you are wanting to know which way to reverse the flow throught it to backflush it?
If that doesn't work and it isn't too expensive for you, a radiator shop should be able clean it for you. Last edited by tripletdaddy; 01-06-2008 at 02:46 AM. |
Do you not have heat or do you have the Brown Sludge problem?
If you just need to get heat. remove the two hoses going into the Heater Core. THis kind of tool works well to break the seal. ![]() After you get them off Shove a garden hose in the outlet and run it for a while. The stick it in the other side and do the same thing. Make sure the problem isn't the blender door. If you have the Brown sludge/coolant issue post back here and I will write the correct procedure up for you to eliminate it. Mike
Both. Its got 185K on it so I figure a temporary fix is good enough. I need to start thinking about replacing it in a year or two, so if I can get heat out of the thing I'll be happy.
I flush my '97 Taurus wagon's heater core every winter because it blocks up every year and I have no heat when the cold air arrives. In the summer time (when it's presumably blocked), the coolant can still flow through the H-shaped (parallel link) bypass hose (Ford's "fix" to make sure a blocked core doesn't build up too much pressure and fail), so that actually works out pretty well because my heater core can't throw off any residual heat into the cabin during the summer.
What I did was make myself a couple of hoses specifically to perform the flush each year. I used two pieces of old remnant garden hose (pulled from the recycling bin at the dump). Make sure they're long enough to drop into your catch basin on the ground (5 or 6' should do it). I chose two separate hoses so that I could have a female coupling at the end of both of them. This way, you can attach both hoses and then repeatedly plug in the male end of your GOOD garden hose to each to flush both ways (for about a minute each time). As far as connecting them, on the water pump side of the engine, if you look toward the firewall but very high up - not down where the elbow hoses are - there is a hose coupling there that you can remove and plug into. On the thermostat side there is a similar connection (it's a very short elbowed hose, if I remember right). You don't have to make either connection at those firewall elbow hoses - which are hard to get to. One other thing I did: I inserted tubular brass couplings into the ends of both garden hoses. These are the serated-looking ones that kind of have to be forced/turned in and then are extremely hard to remove because they have teeth like a shark. Then, I slipped a 6" piece of standard black rubber hose onto the other end of the coupling so that the end result was I had a garden hose remnant with a female coupling on one end and a 6" piece of rubber hose coupled to the other end (this makes the connection to the car easier and more natural). Everything is coupled together with hose clamps. I even leave a hose clamp on the end of one (or both of them) at all times (for connections purposes), and I replaced the clamps on the hoses in the car (that I de-couple) with screw-type hose clamps to remind me where I need to make my connections each year (because it's easy to forget). Ford should've passed out these hoses when they added the H-shaped bypass hose. The bypass hose doesn't do anything to keep the heater core from getting plugged up! |
Or you could just unplug both sides of the heater hoses and stick a garden hose in it to flush the heater core.
There is a way to eliminate the brown coolant altogether . Mike
I would like to know how to get rid of the brown coolant. Please let us know what your suggested procedure is.
This is basically what the TSB from ford originally wrote.
Ford still lists a kit that adds the bypass hose to keep coolant circulating thru the heater core all year round but good luck finding it from Ford. You can get it off a salvage 99 model or newer. or make your own Anyway Drain the your radiator. Leave the petcock open. Pull the thermostat out and reinstall the housing. Pull the degasser tank out The big hose that is in the front will accept a garden hose. The small hose that runs over to the top of the degasser tank needs to be pointed over the fender Turn the waterhose on and run it while the engine is running and the water pump is spinning. after everything finally runs clear Unhook the hoses to the heater core and flush it both ways. Change the water pump Add a grounding strap from the heater core to the Water pump Ford did this in 99 so 99's should have it. Put everything back together including the T stat Run Prestone Super Radiator Cleaner for 3 to 6 hours of drive time. This can be done over several days if necessary. Go back and completely flush the system again. If you had a super bad case of Brown Sludge you can run another treatment of the cleaner. Then add the proper amount of coolant. Installing the Bypass hose, New water pump and adding the ground strap is critical to ensure that the brown coolant doesn't come back. The Vulcan is the only engine that gets this. The Duratec doesnt. A lot of overheating problems are caused by the impellers on the water pump being eaten away. As previously stated. Ford knew about this and finally came up with a kit to correct the problem. They don't offer it anymore and I can't remember what the TSB that lists the kit number is. You can call Ford and they can look it up if you find a parts guy that gives a *hit Mike
Sounds like a case of beer instead of a six pack. What does the grounding strap do? If don't replace the water pump, what happens? Does it come back, or are you taking a risk that the water pump is bad?
The ground strap supposedly stops electrolysis. The water pump on a higher mileage vehicle has the impellers corroded and they don't flow a lot of coolant. The first time I did it to my Vulcan I didn't change the pump out and it came back. I had to do it again six months later and I changed the pump out that time and it hasn't been back. Mike
Not knowing the best way to handle my own correction, I'm reposting this to be sure it get's out, and if it's a duplicate, my apologees in advance.
I have to wonder if Ford's "kit" really solves the brown coolant problem. I bought my '97 Taurus brand new from the dealer (in January '98) and it already had the "H" bypass hose installed. Presumably, the dealer also did the flush, etc. Still, I had the sludgy coolant problem shortly thereafter (and still do). Back in 2003 timeframe, I ended up buying the special flush liquid used in the TSB (ph Iron Cleaner - 2Qt bottle) for $40 from the dealer to see if that would solve the problem - and it seemed to help - but the problem remains to this day.
Possibly the ground strap wasn't installed? I've never noticed any wires running from the heater core to the water pump. I don't think my car has that. I know the water pump is original. I once pulled the hose at the water pump and was horrified when the goose neck came out with it completely corroded! I ended up buying a short piece of brass tubing and hammering it into the water pump with a socket. It's still there (about 4 years now)... |
Changing the water pump on a 97 Vulcan takes a little over an hour for the average wrench.
I would change a 10 year old one just to sleep better at night. Mike
On the water pump it is on the top towards the firewall
Here is where it attaches to the heater core
