Old 01-01-2008, 06:49 PM
alero03 alero03 is offline
alero no go
wife took the car out today{03 alero 2.2] it shut off on her and would start up then shut off then with more atemps to start the batt got to low to crank the motor over...i towed it home ..checked fueses and relays..checked batt voltage it was 11v...checked batt terminals and ground wire on the motor...any ideas what to do now???
Old 01-02-2008, 02:42 PM
maxwedge maxwedge is offline
A990 racer
Re: alero no go
Welcome to AF, get the battery charged to 12.5v, then check for spark, basic diagnostics.
Old 01-02-2008, 04:45 PM
Re: alero no go
defently not the batt...i tryed another batt same thing
Old 01-02-2008, 06:22 PM
A990 racer
Re: alero no go
I was saying charge the battery so you can turn the engine over and check for spark, you left off with a weak battery that wouldn't crank the engine in your original post.
Old 01-02-2008, 06:38 PM
Re: alero no go
batt in the first post was 11v thats lots enough to turn the motor over....the batt is good but nothing works on the car lights/pwr window/radio/....ground on motor is good both terminals are good fuses are good
Old 01-05-2008, 07:11 PM
Re: alero no go
i changed the ing switch today and it dident make a difference
Old 01-07-2008, 09:54 AM
scoopy03 scoopy03 is offline
Re: alero no go
passlock? turn key to on dont start leave for 10 mins then switch to off for a sec or 2 then try to start if not then it is a different problem.
99 olds alero 2.4 DD
92 notchback with 460 carb'ed
