Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 01-01-2008, 05:29 PM
WendeeBird WendeeBird is offline
Rodeo wont start.
Hey, I've spent about an hour reading threads to see if i could get my answer without posting. i give up.
my problem... i tried to start the car this morning and it wouldnt start. when i turned the key i could hear the fuel pump, but i just got a single click from the ignition. the security system light thing is flashing, so i dont know if it is the anti theft or what. i read a post where someone ran out of gas and then the car wouldnt start, one of their suggestions was to disconnect the battery for 30 minutes to reset the ecu. i disconnected my battery because at this point ill try anything. i did that about 10 minutes ago, so i guess ill see. does anybody else have any other ideas? i really appreciate it. i just bought this car yesterday, and being that its new years day, the dealership isnt open... no where is really open. thanks.
-Wendee
Old 01-01-2008, 07:47 PM
FL 3.2L FL 3.2L is offline
Re: Rodeo wont start.
What year? Miles? 4X4 or 2 wheel drive? It sounds like the starter quit. Make sure all of your connections are clean. Did you get it to start at all?
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 01-01-2008, 10:00 PM
Cat Fuzz Cat Fuzz is offline
Bad starter. A jump start might get you going temporarily but the starter solenoid contacts have gone bad.
Old 01-02-2008, 01:30 AM
trooperbc's Avatar
trooperbc trooperbc is offline
Originally Posted by WendeeBird
...i just bought this car yesterday, and being that its new years day, the dealership isnt open... no where is really open. thanks.
-Wendee
yes it does sound like the starting system, so first check all the connections and wires to and from the starter, as well as the battery connections (not to mention the condition of the battery).
and then look to a good independent parts store for a quality rebuilt (remanufactured) starter. i would suggest remanufactured by bosch for quality and value (not cheapo, but less by far than the dealer).
good luck
//bc
btw, disconnecting power to the computer, either by removing the fuse or disconnecting the battery for 10 seconds is all that is necessary to reset.
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Old 01-02-2008, 01:43 PM
Andie_J Andie_J is offline
Mine did the same thing, but I got 2 clicks. Id left the headlight on for 2 days and all it took was a jump start. After a jump start and running for while everything was fine. Andie
O4 Rodeo, 3.2, Auto, OME's 912's, Kangaroo Chaser
05 Saab, (My two BABIES)
Assorited Pickups for the ranch
Old 01-02-2008, 02:58 PM
I whipped up a cheesy little diagram to help explain what happens when a Denso starter does this. Ph34r mah 1337 arsty fartsy-ness!!
Not.
