Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-01-2008, 03:50 PM
deesandvees's Avatar
deesandvees deesandvees is offline
'87 Caprice 305 wiring from the computer unit
I've got an '87 that came with the 305 and I'm going through every single wire that comes out of the firewall. I've got the factory service manual and factory electrical supplement also. The left side was easy, headlights, windshield wipers, etc., because the electrical service manual has a diagram of that harness connection at the firewall with all the wire colors and everything. But I'm on to the right side and can't seem to find what I need to figure out the big bunch of wires coming out of the firewall on the right side under the ac box. I want to make sure I know what all this is because I'm getting ready to hook up my rebuild (383) with an edelbrock performer carb and I know it seemed like there was a million things hooked up to that electric carb that's now sitting up on a shelf in my garage collecting dust.
Old 01-01-2008, 03:54 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: '87 Caprice 305 wiring from the computer unit
I hope you're not expecting the computer to work!
The large bundle of wires that 'comes out from below the A/C" is the computer harness.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-01-2008, 05:08 PM
Blue Bowtie's Avatar
Registered Offender
A 383 is about perfect for a QuadraJet. Why limit yourself with an Edlebrock clone of a Q-Jet? The E4ME can flow up to 780 without modification, more if you tinker. Beyond that, you'll be able to keep the ECM and program timing curves that are impossible with any mechanical/vacuum distributor.
I'd keep the carb and ECM wiring intact. You can find schematics all over the www, like at autozone.com
Old 01-10-2008, 10:52 AM
I might be keeping the q-jet at this point. I need to go through the ECM harness though and can't find schematics on that mess of cables coming out of there. There's a couple wires that I see are severed with no ends on them and a couple very small vacuum tubes that go to nowhere. Any help on that?
Old 01-10-2008, 12:00 PM
silicon212's Avatar
Confoundingly Lucid
You can get the Haynes 1969-1990 Chevrolet B-body manual, which has schematics at the back of the book. It doesn't specify wire color, so you will need to trace the wires to their sensors.
The two vacuum lines should be the A/C control. The brown one will go to the heater bypass valve, and the white one will go to the vacuum supply, which is usually an orb-shaped reservoir on the A/C evap housing.
Old 01-10-2008, 01:13 PM
Thanks Silicon, I've got the factory service manual and the electrical supplement too, does it have this info in there? I was able to identify all the under hood wiring coming from the fuse box with the electrical manual but not sure if there's a good resource for the ECM in there, at least I couldn't find a page as easy to understand as the page for the fuse box harness. If not I'll get the Haynes.
Old 01-31-2008, 04:05 AM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
the books arent going to tell you everything about every ECM wire
there were many different variants of the ESC and EST carb systems
some had knock sensors and some didnt, some had AIR pumps and tubes and some didnt(wires for the pump and parts are inside the same harness), some had a different number of wires running to the carb than others, such as some of the 80s 305 trucks that only had a single black wire running to the top of the E4ME carbs, unlike most other E4ME carbs
and some had sensors that others didnt,
all depending on the exact make model year and selling/dealer location it was built for
48 state
federal
canada and so on
you wont get every wire detail in any given book schematic
what exactly do you need to know
what are you trying to do ?
you have to make up your mind if you are going to run ESC/EST or not
if no then remove that entire harness
if yes then leave it alone
pick one
good luck!
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 01-31-2008, 08:49 AM
That's what I ended up going with, ditching the entire harness. Thanks for the info.
