Old 01-01-2008, 11:45 AM
LastOne LastOne is offline
5.7 Stumbles when Oil fill cap removed
Buddy of mine has a 98 c1500 like mine. He has a bad miss on cyl 6. He removed his oil fill cap with the engine running for some reason I can't remember and it stumbled like you removed the vac hose going to the brake booster. It recovers and runs like it did with the cap on. When I remove my cap with the engine running, no change. We checked the EGR valve. Any other ideas?????
Tks in advance.
Old 01-01-2008, 01:27 PM
16th hippy 16th hippy is offline
Re: 5.7 Stumbles when Oil fill cap removed
check pcv system, especially the valve.
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 01-01-2008, 04:12 PM
PCV valve already replaced / swapped with mine. Keep the ideas coming
Old 01-01-2008, 05:13 PM
restrorob's Avatar
restrorob restrorob is offline
Do a compression test on this skipping cylinder, You may find a blown head gasket.
1974 Chevy Long Box
Body Off Restoration And Customization In Progress
Old 01-02-2008, 03:18 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Make sure the vent hose isn't plugged.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
