Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 01-01-2008, 12:10 AM
95Talipse 95Talipse is offline
Transfer case??....HELP
Hey...so for a while my car was clicking loudly if i let off the gas and then all of the sudden a week later i was driving (not beating on it) and it was like clink, grind, pop, and it stalled out i started it back up and i was finally at my girlfriends house...started it up and tried to put it in 1st and take off...i let out clutch and didnt move and stalled out...the next day i went back and jacked t up and and put it in 1st gear it grinded then large amounts of oil coming from transfer case area...?...what do u guys think??...Thanx
-95 Talon Esi-
Old 01-01-2008, 12:12 AM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: Transfer case??....HELP
I hope this isn't the car in your sig...
Yoke seal? cracked case?
EDIT: I remember for about a month my car would knock or click before it totally spun a rod bearing and it always did it when I let off the gas. Under load it never knocked. Food for thought.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 01-01-2008, 12:27 AM
Yeah its the car in my sig...im pissed i hope its not alot of money to fix...maybe i is a rod bearing thats what i thought...but the oil?..
-95 Talon Esi-
Old 01-01-2008, 12:38 AM
Testiklees
OK, well you can eliminate the T-Case since you don't have one. They are only on all wheel drive models. Did you mean from the transmission? What kind of oil is it? motor oil, gear oil? what color was it? do you have an auto or manual?
When you first start your car after its been off for awhile, does it do the clicking things for a second or 2?
Tim
1990 Talon AWD
PTE SCM5031
Old 01-01-2008, 12:44 AM
o yeah a 5 spd....black oil not sure what kind....not good with motors...motor oil i believe and no does not tick when start up only when i let off gas...but does not go any where anymore
-95 Talon Esi-
Old 01-01-2008, 12:52 AM
Testiklees
You are going to need to check the levels of both to see which one it was.
So you can start it, it just stalls when trying to go into gear?
Tim
1990 Talon AWD
PTE SCM5031
Old 01-01-2008, 01:50 PM
boarder4life boarder4life is offline
does it make that clicking sound when u let off the gas when its in gear? as compared to out of gear?
Old 01-01-2008, 02:21 PM
yeah well now it doesnt drive it just stalls out when u put it in gear and let out the clutch...but before it only clicked when it was in gear letting off the gas.
-95 Talon Esi-
Old 01-02-2008, 01:53 AM
sounds like you were leaking gear oil. check if there is any oil in the transmission.
