| Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs |
I need your opinions.
Hey guys I am buying 33 inch bfg's and I am considering a 2 inch body lift from AC. what are your opinions on this kit. whether you have it or not I would like to hear your opinions. also if I do get the lift one should I go for 33x10.5 as I plan or go to 33x12.5. I already have a 3 inch suspension lift. If you have done it before what have your experiences been Do you believe the 2 inch AC kit is very complete or should I go for the 3 inch kit .
thanks in advance for your info. |
Anti-Treehugger has 33's and went with 10.5" I'm not sure where he got the body lift from. You might PM him.
I wouldn't get the 12.5's. Too much weight and width. Unless you're just staying on road. |
Nah I definitely want them for wheelin. If not I would go for at's. I was planning on the 10.5's for the sake of avoiding rubbing and still gaining height. I was just worried about side lug traction with a tall but thin tire. Would I be subjecting my sidewalls to undue stress while aired down. Also with the added height of tires and body lift would the thinner tires become a liability.
I don't think sidewalls would be much of a concern. I think the 33X10.50's would be the best bet if going to a 33" tire on the Xterra. Will require alot less work to fit, and will be alot less stress on steering components.
Just be prepared,
for the HUGE power loss going to 33's. If I remember correctly you are running 31's. When I went to 32's it was VERY noticeable. After putting on my IV intake and Gibson exhaust, it seems that my power is back to stock. I still am a little slower than stock on the freeway going up the mountains, but otherwise it's about the same. I do think that it's got better pickup speed now though. I don't know how much actual benefit you'll see between the 32's and 33's, except what's been noted and a considerable decrease in gas mileage.
I was thinking about doing the same 2" body lift, but I think I'll stay with 32's just because I can't afford new gears and I don't want anymore power loss.
SLR 3" Lift, SLR IV Intake, SLR Steering Stabilizer, 32" BFG MT km's, Warn Premium Locking Hubs, Gibson Exhaust, Custom Rock Sliders, Custom Safari Rack, CO2 Air Tank, Daylighters, CB, with more to come. |
I am running 33x12.5 xterrains with 3"+2"BL from AC.
Automatic Comments. AC 2" kit was alright. Not the best, certainly not the worst. Install instructions were confusing. Didn't really have to do all the steps. I didn't relocate my radiator, extend my t-case shifter, extend the fuel filler line, or buy there rear bumper relocation bracket. Redrilled rear bumper, enlarged the t-case shifter hole, and removed bottom piece of radiator fan shroud instead. The rear most body mount bolt they sent was too short. Instead of sending a longer bolt they just sent a steel pipe spacer. Not the best solution but works. You will need to relocate the front bumper depending on what you got up there arb/stock. Power loss is not that bad. But I have an auto, not sure how it feels in a stick. I just drive around with the overdrive shut off. Gas mileage sucks plain and simple but what can you expect. I would go with 33x10.5 if you don't want to trim excess amounts of metal and plastic up front. 12.5's will rub. The 3" body lift is probably a real pain. A lot of things need to be relocated. Right now I am at the limit with the brake lines, power steering reservoir, and fuel lines. Can't forget about steering either. Hope this helps. |
