Old 12-31-2007, 06:32 PM
jprish jprish is offline
Cranking problem
Hey all,
I have a 97 Cherokee with some intermitent cranking problems. I turn the key and nothing. No sound or rattle so I think starter. I will try later and it will be fine. Any ideas, dirt ignition wires, bad starter, I don't know. Anyone have this problem.
Old 12-31-2007, 06:35 PM
RaeRae1's Avatar
RaeRae1 RaeRae1 is offline
Send a message via AIM to RaeRae1
Re: Cranking problem
Originally Posted by jprish
Hey all,
Need more info - do your interior lights stay on? Have you checked the battery cables to make sure they are not corroded or loose? Is there any kind of clicking noise?
Blessed are the cracked ones, for they are the ones that let in the light.
Originally Posted by 72chevelleOhio
Your cheer-mobile needs a flat tire.
Old 12-31-2007, 08:00 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Hey all,
My 97 had a bad ignition switch. Testing can be done with a voltmeter.
You can use a remote starter switch, the mechanic's kind, direct to the starter to test. It that doesn't run the starter every time, then look into the starter solenoid.
Remote starter type:
http://www.justoffbase.co.uk/Tool-Shop/Remote-Starters
Old 01-05-2008, 05:06 PM
Thanks for the input guys. It hasn't happened again but I will try what was posted if it does.
Old 01-05-2008, 08:35 PM
Saudade's Avatar
Saudade Saudade is offline
Neutral safety switch. If yours is an automatic, try shifting into neutral.
Dad's taxi:
'88 XJ - 190K and going strong.
K&N, Ford Injectors, No other mods
Old 01-06-2008, 07:24 AM
I went to Autozone and they ran the computer. It came up with 700 and 705 which they also said neutral safety switch. I used my Haynes manual to troubleshoot the switch and it apparently seems good. The male end of the switch was different from the example but I got continuity on all terminals. I really don't want pay 250 for a new so I want to make sure first.
Old 01-06-2008, 10:16 AM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
I was having the same problem with my 92 sport when I first bought it and checked the NSS and it tested good as well. But it was still bad in it's own quirky way, check this article it tells you how to rebuild it instead of replacing it.
http://www.go.jeep-xj.info/HowtoNSSrebuild.htm
Old 01-06-2008, 10:59 AM
Saudade's Avatar
NSS's are notoriously intermittent as you have observed yourself. Carefully remove it and clean as per the link Dave provided.
Dad's taxi:
Old 01-07-2008, 05:00 PM
Thanks everyone for the advice and article. I will put it on lift or jacks and see if can fix the switch.
