A.b.s Blues
I HAVE A 1997 PONTIAC GRAND AM ABS PROBLEM WHEN I PRESS THE BRAKE PEDAL ABOVE 20 MPH I GET A CLICKING NOISE FORM THE ABS PUMP I HAVE SCAN THE ABS SYSTEM WITH A SCANNER WITH NO CONCLUDION AND ALSO THERE ARE NO CODES THE ABS SEEMS TO BE WORK PROPERLY BUT THIS ANNOYING NOISE IT MAKES ALSO I NOTICE WHEN I PUT THE SCANNER TO IT THE CAR START TO RUN FUNNY AND ALL TYPE OF CODES ARE FLASHING IN THE ABS MODE WHILE SCAN IT CAN ANYBODY HELP WITH THIS POSSESSES CAR.
Re: A.b.s Blues
This sounds like a problem with the wheel speed sensor in one of the wheels. If one of the sensors is going bad it will cause the ABS to read falsely and cause the ABS to activate. This is probably why you get numerous codes when the car is being scanned while driven. There is a possibility that more than one sensor is gosing bad.
AFTER HOOHING UP THE SCANNER TO IT TEN MINUTES OR SO THE SCANNER STARTS TO SPIT OUT ALL TYPE OF CODES AND AT THIS TIME THE ENGINE STARTS TO STALL OR CUTS OFF REPEATLY AND THEN ONLY THEN THE ABS LIGHT COMES ON BUT WHEN I DISCONNECT THE SCAN TOOL AND RESTART THE VEHICLE IT SEEMS TO BE FINE BUT THE CLICKING NOISE FROM THE BRAKE PUMP IS SILL THERE PRESSING DOWN ON TO THE BRAKES PEDAL OVER 20 MPH AND THERE ISN'T ANY ABS LIGHT ON DO YOU THINK IT COULD BE A BAD GROUND OR A BAD MAIN CONPUTER ?
Re: A.b.s Blues
It is very possible that you have a bad ground on the chassis or on the computer. I would check every ground you can find but start with the one from the battery to the engine block. The wire can internally corrode and cause issues even though it looks good on the outside. Also be sure to clean the terminals. As for the computer it could be bad but that would be the last thing to replace.
Re: A.b.s Blues
i will look in to that because for kicks i had replace the abs computer before and the problem still there i will let you know what become of it happy new year
