Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-31-2007, 01:36 PM
boarder4life boarder4life is offline
igniton timing
I just rebiult my tsi. went 30 thou over on cylinders and polished the crank. i have it timed to 5 degrees BTDC. but it runs like shit, i was told from a couple people when you rebiuld an egine the timing has to be adjusted accordingly. i guess i was just wondering if u could tell me where to time it to to compensate for bigger cylinders? thanks.
Old 12-31-2007, 01:54 PM
Re: igniton timing
also, my turbo seems to be leaking oil into the exhaust. is this a sign of a bad turbo? the drain pipe from the turbo to the oil pan is clean. i cleaned it twice and its burnin alot of oil. its defenatly through the turbo though. not rings. any help would be greatly appreciated. im kind of new to the whole turbo system. thanks.
Old 12-31-2007, 02:37 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: igniton timing
What car do you have? Year, model, mods, etc will help. You say you timed to to 5* BTDC, why did you do that? We have timing marks on the cams for our cars, you don't time them with a light like the older ones.
95 Talon TSI AWD
97 Eclipse GST
Old 12-31-2007, 09:16 PM
Re: igniton timing
I timed it to 5 degrees with my light because thats what it says under the hood. on the sticker. its a 93 2.0 turbo.
Old 12-31-2007, 09:19 PM
Re: igniton timing
the cams are timed perfectly to the crank. i did it myself. the balance shafts are gone, and cylinders are bored 0.5mm. thats all so far.
Old 01-03-2008, 12:24 AM
Re: igniton timing
so noone knows what degree this thing should be timed to?
Old 01-03-2008, 12:36 AM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: igniton timing
If it is truly at 5 degrees BTDC, then you should look elsewhere for the problem. Did you do it like this: http://www.plymouthlaser.com/timin.htm
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
