Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 12-31-2007, 01:20 PM
Skept.2 Skept.2 is offline
86 corolla problem
I was wondering if anyone ever encountered this problem. When the car first turns on, the engine light is on and its over 2,000 rpm's, If I don't let it warm up a lot, when it drives it'll suddenly turn off on me and it will take a while for it to turn on. Then when it turns on it's back to normal.
I have check diagnostic codes and got a 4 and a 7
checked the tps and everything, and after that instead of getting a 7 I get an 11, 11 Is the number I do not know.
any help appreciated =)
Old 01-03-2008, 08:24 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: 86 corolla problem
I'm not overly sure about Toyota, but most TPS of the dya were adjustable and operate in a set volatge range (reference) used by the ECM to determine throttle blade (butterfly) position. Might want to check and make sure the teh TPS didn't come loose or get wet. A faulty TPS reading will cause your idle issue.
On a side note, wich model in 86 used EFI, I thought they were all carb til the 89-90 model?
Old 01-08-2008, 02:13 AM
kunfuzion kunfuzion is offline
sr5 corollas are carb, gts are efi.
Old 02-04-2008, 02:32 AM
sparkeykev sparkeykev is offline
Send a message via Skype™ to sparkeykev
11 is system normal
Old 03-08-2008, 10:38 PM
rockwood84 rockwood84 is offline
have you changed the pvc valve as this will make it stall out?
