Old 12-31-2007, 10:28 AM
EricT EricT is offline
Door Adjustment
Hi, I'm new to this forum and probably am posting a question that has been asked before. Please excuse the my ignorance.
Does anyone know how to adjust the side doors on a 95 c/k.
The mauals that I have found only relay adjustments to the latch mechanism.
Any help would be appreciated.
Old 12-31-2007, 06:55 PM
restrorob's Avatar
restrorob restrorob is offline
Re: Door Adjustment
Eric,
The majority of assumed needed door adjustments are due to worn hinge bushings/pins, Check them for wear first.
There is really no set procedure for door adjustments. It's just a trial and error procedure and takes patience, If you can give a idea of what your door is doing/where it's hitting someone may be able to point you in a direction to start.
1974 Chevy Long Box
Body Off Restoration And Customization In Progress
Old 01-02-2008, 07:01 AM
Re: Door Adjustment
I replaced the pins in the hinges and the door still is not aligned properly.
The door drops about 1 to 1-1/2 inch when it's open.
My brother in law has the same problem with his 95 c/k.
It appears that there are no hinge bolts to adjust the door up and down.
I am confused as to how the alignment process is to be done.
Perhaps the hinges have become slightly bent...?
How do they fix this if the vehicle is involved in an accident where the hinges are damaged?
Any help will be appreciated.
Old 01-02-2008, 02:45 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Door Adjustment
If all you replaced was the pins, you will need to replace the bushings as well. They are what actually wear.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-02-2008, 07:19 PM
restrorob's Avatar
Re: Door Adjustment
If your door is dropping that much I'd say you have something broken or the bushings wore so bad they broke and fell out, Have someone lift the door up and down while you look at the hinges and see where all the movement is at.
Probably just bushings like J-Ri mentioned.
1974 Chevy Long Box
Old 01-03-2008, 08:15 AM
Re: Door Adjustment
I replaced the bushings at the same time I replaced the pins.
It dosnt make sense to me.
My brother in law has the same problem.
I'll take a few pictures tonight so you can see what I mean.
