Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-30-2007, 09:26 PM
nozelle nozelle is offline
99 Rodeo Lights Flickering
My 99 Rodeo lights (interior and exterior) began flickering this weekend when it is idling. When the engine is above 1500 rpm the flickering stops. Idling when the battery terminal off the flickering persists. The battery seems to be charging fine since the vehicle did not shutdown when the battery terminal was lifted while it was running. I do not have a "boom box stereo system" to mess with the alternator.
Has anyone encounter this problem before? Could it be the alternator going bad? I plan to check the ground wires in the engine and some fuses to see what I find. Looking forward to hear from you guys.
Old 12-30-2007, 11:08 PM
andrew_j's Avatar
andrew_j andrew_j is offline
Re: 99 Rodeo Lights Flickering
rodeo's act really weird when the alternators go bad.
if you replace it either get a bosch napa or oem isuzu.
cheap ones will die very quickly
1996 Honda Passport EX 4x4
On it's way to 161k FOR SALE!!!!
2000 Acuera Integra LS 5 speed
Old 12-30-2007, 11:44 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
I agree with alternator.. my mitsu did the same thing when the alternator went bad. You'll probably see the headlights do the same thing.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 12-31-2007, 05:07 PM
Well what you know-I found a blown hrin fuse 10a in the engine fuse box. Once it was replaced the lights stopped flickering.
The horn hasn't worked for a while, I had the relays in the "alarm box" (front passenger side) checked and they are all good. This latest discovery may indicate there is still another problem.
Thanks for the input.
Old 12-31-2007, 05:22 PM
Gizmo42's Avatar
Gotta love isuzu wiring. Something so simple causes weird things to happen in seemingly unrelated parts.
Its possible you could have a bad ground somewhere and something else is using the horn circuit to complete its circuit.
--Dave
Rear No-Slip Locker
