Old 12-30-2007, 08:12 PM
79403ta 79403ta is offline
blowing fuse
1997 chevy K1500 with the 5.7 and 4l60E....i am having problems with my tail light fuse popping it started about 3 days ago and i havent been able to find the short...i put new circuit boards in the tail lights...one did have a bad spot but it didnt fix the fuse problem ...any ideas possibly headlight switch ?? when the fuse blowed the first time i put a new one in and it lasted about a day then the second fuse about 15 minutes now it pops in about 2 minutes...i know its not good to keep putting fuses in and popping them but i havent had time to trace every wire yet and i figured i would see if their was an easier fix..... nothing has been added to the truck or changed electrically
Old 12-30-2007, 09:35 PM
463's Avatar
463 463 is offline
Re: blowing fuse
if you have a trailer plug in the truck the wire may be the problem eg: damp or wet mud on broken wires or wet/damp mud or dirt in the plug. you could have a ground wire thats not grounded. this will normally have the signal lights flashing at twice the normal speed. just some food for thought. 463
Old 12-31-2007, 11:38 AM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Re: blowing fuse
I had the same problem. It ended up being a bare wire in the trailer wire harness. Replaced the harness & everything was fine.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 01-01-2008, 01:30 PM
16th hippy 16th hippy is offline
Re: blowing fuse
something i have seen a few times was the wire behind the kick panel by the parking brake pedal, sometimes it gets chafed. may not be the problem, but an easy check besides sending it to the shop
Disclaimer: I am not perfect, i may be wrong in my advice from time to time. Also note that any advice given is as is with no warranty whatsoever, and i have zero liability if you get hurt for not being safe while working on your vehicle.
Old 01-01-2008, 05:45 PM
Re: blowing fuse
replaced the tail light circuit boards one side was burned completely into , one front side marker bulb the tiny ones on the side (not the parking light bulbs on the front) and a headlight switch..problem fixed
