Old 12-28-2007, 04:35 PM
s10manic s10manic is offline
Question Throttle Body Cleaning
i have a 96 s10 with the 4.3 V6 and the other day when i went to change the sparkplugs we took off the air intake and when i opened the butterfly valve i saw about a half an inch of hardened Black stuff... and i was wondering how to get it off..
Thanks
Old 12-29-2007, 12:05 AM
eborn eborn is offline
Re: Throttle Body Cleaning
just spray some carb cleaner on a rag and wipe it out....its usually just carbon build up or dirt
Old 12-29-2007, 12:07 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
For the bad carboned up ones carb cleaner or TBI cleaner and a old tooth brush works good.
Just like brushing your teeth.
Soak it and scrub and brush and wipe it away.
Good Luck
MT
MT
Old 12-30-2007, 05:23 PM
ok but question.. would it hurt it if i was to stick a screwdriver up under it and pry it out?
Old 12-30-2007, 05:36 PM
blazee's Avatar
blazee blazee is offline
Problem?
Half an inch would be an extremely abnormal amount of build-up and would certainly cause a lot of driveability issues. Are you sure that you're not seeing the air deflector which is supposed to attached to the underside of the butterfly?
Old 12-30-2007, 05:38 PM
well im still trying to figure this truck out.. so i didnt know there was an air deflector and if thats what it is than there is still build up on it
Old 12-30-2007, 05:45 PM
blazee's Avatar
Problem?
If it's just the deflector with a little carbon on it, then using the TB cleaner and toothbrush with it in place will be okay. If you are really see a large amount of carbon build up (enough to pry off with a screwdriver) I would recommend pulling the throttle body off and bench cleaning it to keep any large chunks from falling into the plenum.
Old 12-30-2007, 05:46 PM
ok.. is there anyway of finding a diagram of the throttle body for my truck?
Old 12-30-2007, 06:14 PM
4.3 Throttle body
I noticed on my throttle body that there is an air deflector is there really a need for it? if not is there a way i can take it off?
Old 12-30-2007, 06:49 PM
maxwedge maxwedge is offline
A990 racer
Re: 4.3 Throttle body
Since you did not post the year, ( chronic issue on all the forums) I assume it is a 96, no do not remove the deflector.
Old 12-30-2007, 06:51 PM
it is an 96 but the reason ask is because one of the things that hold it on popped off what can i do about that?
Old 12-30-2007, 07:19 PM
old_master's Avatar
Advisor/Moderator
It is held on with rivets, but, there is also a bleed hole that is supposed to be open.
There are several threads in the forum claiming that removing the deflector improves performance, don't believe them, it is there for a reason.
Old 01-05-2008, 05:36 PM
Question 96 4.3 Question
i got a 96 s10 with the 4.3 Vortec and i was wondering why gm put an air deflector on the butterfly valve?
Old 01-05-2008, 08:32 PM
old_master's Avatar
Advisor/Moderator
Re: 96 4.3 Question
The main reason is to reduce throttle sensitivity so it's not so "jumpy" from a stop.
Old 01-05-2008, 08:35 PM
Re: 96 4.3 Question
so if you were to take if off is it gonna hurt the engine?
