Old 12-30-2007, 06:22 PM
sixwongs sixwongs is offline
2002 Chevrolet Cavalier Headlamp Assembly bulb replacement
Having trouble trying to replace the bulb in the drivers side headlamp assembly.
I unscrewed the top 2 bolts to the assembly, but it seems to be held by the
side lamp can't tell where it's connected? how do you separate the two?
Thanks
Old 12-31-2007, 07:04 PM
Re: 2002 Chevrolet Cavalier Headlamp Assembly bulb replacement
When you your working from the front of the car.
I can get the left side of the drivers side headlamp assembly loose from the retaining bracket, but the right side seems to be locked together with side marker assembly. There must be a trick to unlocking it from the side markers assembly. I don't see a clip. The side marker assembly doesn't seem to detach easily. The two pieces seem to be pinned together with molded pins on the side marker assembly. When I lift up on the headlamp assembly, I can see the side marker assembly retained by the same type of retainer on the headlamp assembly. The only problem is you can't lift the side assembly up.
I am trying to this as carefully as possible to not break any of the plastic components.
Thanks
Old 12-31-2007, 10:15 PM
quake61's Avatar
quake61 quake61 is offline
Thanks
if is the same as the 2000, after you unscrew the top 2 bolts, there is a clip in the bottom side of the assembly. try pulling out bottom first.
look at the bottom of the assembly, do it gently because the clip is plastic too
try prying it out bottom first a little then top and so on it must come out
