Old 12-30-2007, 03:09 PM
oempartssupply oempartssupply is offline
97 1500 I think engine is locked up what do you think
I have a 97 1500 with the 5.7L Vortec. I was on my way back from OK City pulling a car. I was on the way down a hill when the engine started making a noise like sticking a screwdriver in a fan. The sound would start then stop then start then stop then the noise started and the engine died. After that the starter would not turn the engine over. This was at 2am we had to wait until 12:00 the next day before somebody came and picked us up. I pulled the starter and it appears to work just fine. I kinda got a wrench on it and tried to turn the engine with my hand with a bar on the end of the wrench but I had no luck. Any sugestions?
Old 12-30-2007, 03:44 PM
CD Smalley CD Smalley is offline
Re: 97 1500 I think engine is locked up what do you think
I think you are stuck... Sorry.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 12-30-2007, 07:15 PM
What do you think I need to do? What would be the easier thing to do, Replace the engine or have this one fixed. What could have caused it?
Old 12-31-2007, 12:37 PM
gremlin96 gremlin96 is offline
hmmm it could be ether the trany or the motor. just because you can not spin it by hand does not mean its locked up. you must be sure of what part to start with.
if i was to bet. your going to be changing the motor. but to be sure block the truck so i will not roll. then try turning over the motor with the trany in neutral.
Old 12-31-2007, 06:42 PM
restrorob's Avatar
restrorob restrorob is offline
Putting the trans. in neutral will do nothing if the front pump locked up.
1974 Chevy Long Box
Body Off Restoration And Customization In Progress
Old 12-31-2007, 09:04 PM
Well today I took and while it was in park the starter would act like it was hitting but not turning the engine. While it was in netural it would not do anything. It is an automatic. What do you think is my next move?
Old 01-01-2008, 07:21 AM
restrorob's Avatar
Pull the engine and drop the pan, Start checking rod and main bearings.
1974 Chevy Long Box
Old 01-01-2008, 08:18 AM
tempfixit tempfixit is offline
Why not disconnect the torque converter from the engine before disassembling anything to see if engine is locked up or tranny is the problem??
Old 01-01-2008, 09:02 AM
restrorob's Avatar
If the engine won't turn you can't rotate the torque converter bolts down to the inspection cover opening for removal.
Once the engine and torque converter are removed together then the engine can be checked again and the oil pan removed for further inspection if needed.
1974 Chevy Long Box
