2005 Colorado heater fan blows only on 4...
Does anyone know how to fix a blower that works only on setting 4? I'm sure it's some kind of fuse or module that's gone out, but I can't find any information about where it is or how to get at it.
Thanx in advance! |
Re: 2005 Colorado heater fan blows only on 4...
Your fan motor resister needs to be replaced
Ok, thanx! But where is it in the truck so I can pull it out and get a new one?
If you're still under warranty, take it to the dealership.
It's on the fan motor assembly under the glove box. It's number 1 in the image below. Most cases its just the resistor that needs to be replaced. Pull and inspect the contacts for any burning or melting then replace if necessary. ![]() www.gmpartsdirect.com Resistor - PN 15218254 Connector - PN 15306069 Complete wiring harness - PN 89019124
Ok, thanx!! That's EXACTLY what I needed to know!!
No, it's not still under warranty (out by 6k miles, naturally), but I know where there's a wrecked (tboned in the bed) 2005 Colorado in a junkyard in town...much cheaper there than the dealer! ![]() EDIT: Oh, I just noticed you added the part number and a place to get it...I may just get the resistor from there, I was told it'd be around $200.00 by a guy at work. |
$200?????!!!!! WoW lol
Even if you bought all the parts listed above through gmpartsdirect it will only be $50.81 + shipping ![]() It only takes about 30 minutes to R&R all parts.
Thanks for the image and info DBNissan. I'll show that to my son so he can fix it too
Hey, my blower was only working on 4, i rode a speed bump too hard and it just start to work normal again.
got another problem, whenever i turn my steering wheel all the way, my engine stut out. a frind told me its the throttle valve. where can i locate it. |
i had the same problem.
there is an electrical connector underneath the dash, passenger side. the connector may be coming loose. i had to secure mine with a wire tie. |
Usually when you tap on the motor to get them running it is a bad motor.
Check for voltage at the plug when it won't run. |
Typically, it's best to swap the resistor and the plug. The plugs are known to melt and have a faulty connection. I have not heard of fan motors going bad.
