Old 12-30-2007, 09:44 AM
brutis5 brutis5 is offline
transmission issue
Hello, i change the spark plugs on my 1996 s10 4.3. even #5 cyl. I spayed 2+2 carb cleaner down into the throttle body to get rid of all the black carbin build up. now when i start it up and put it in gear it slams in hard. it also shifts at 2500 rpm on the 1-2 shift, and i have no kick down when accelerating hard. i don't see a thottle valve cable to adj the shift points like the 700r4 tranny. what controls the 4L60e tranny shift points
Old 12-30-2007, 10:00 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: transmission issue
The carb cleaner could have wiped out your TPS sensor.
Did you leave anything unpluged when you put it together?
The transnmission is PCM/VCM computer controled.
You will need a engine /transmission scanner to check it out for codes and sensor operation.
Watch and check the tps reading real close.
And post back any codes.
MT
MT
Old 12-30-2007, 10:14 AM
i just put my scanner on and a code came up tps issue. but my check engine light must be bad, because its not on . thanx
Old 12-30-2007, 10:20 AM
MT-2500's Avatar
AF - Advisor
What was the code no.
I think you have found the problem.
A PROBLEM DOES NOT ALWAYS TRIP THE ENGINE LIGHT REAL FAST.
Does the check engine light come on for a bulb test when key is first turned on?
Fix the tps sensor/code and let us know how it goes.
MT
MT
