Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 12-30-2007, 12:28 AM
slider56 slider56 is offline
Rubbing sound
Hi there,
I have a 2003 Lincoln LS. Whenever I take the car out at the beginning of the day, or after the car has been parked for a few hours, I hear a rubbing sound coming from the car. To be honest, it sounds like something is scraping against the tire. After I have driven the car for 20 minutes or so, the sound disappears. The sound kind of speeds up as I drive the car faster.
I have already checked the tires and they are not rubbing against anything. Also, everything is stock on the car.
Any ideas?
Thank you.
Old 12-30-2007, 01:11 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Rubbing sound
Welcome to the forum!
Does the noise change during turns, or when the brakes are applied? What if you shift to neutral while cruising down the road? What do you mean by "kind of speeds up as I drive the car faster?" Does it seem related to vehicle speed, or are you suggesting it may be related to engine speed?
-Rod
Old 12-30-2007, 03:43 PM
Re: Rubbing sound
I am not sure if it is related to engine speed or vehicle speed. With regards to turns, I don't know how it is really effected because I have to slow down, and the sound slows down with it. Basically, it is an intermittent sound that becomes much more frequent as I go faster. It's not the constant hum I heard when I had to get my wheel bearing replaced.
When I am driving on the street, it sounds like: rub...........................rub................. ...rub.........................rub when going at about 35.
When I am on the freeways, it sounds much like:
rub....rub....rub.....rub....rub and it slows down as I slow down for a turn or to exit.
Let me try and shift the car into neutral when I am crusing and will let you know what happens.
Thanks.
Old 12-30-2007, 08:20 PM
shorod's Avatar
SHO No Mo
Re: Rubbing sound
You may want to consider having your tires inspected for separated belts.
-Rod
