Old 12-30-2007, 12:23 AM
sestewart9200 sestewart9200 is offline
gauges jump with key on but won't start
I turned the key to the on position and my gauges start jumping erratically, but when I try to start they stop. I can hear a relay tripping in the engine compartment. I can also hear a small motor running in the engine compartment. I just had the tranny rebuilt and had to replace the battery. Also, yesterday my car died when I slowed down to make a turn twice, I just put it in neutral and it started right up with no problem. Any Ideas?
Old 12-30-2007, 03:47 PM
maxwedge maxwedge is offline
A990 racer
Re: gauges jump with key on but won't start
Welcome to AF, year, engine??
Old 12-30-2007, 06:15 PM
j cAT j cAT is offline
I don't know much with the info you supplied and work just done so i am guessing , that the mechanics forgot to tighten battery connections/ ground connections so look for wires to carbody to be secure also you will , i'm guessing now , that the battery will have to be exposed as it is buried benneth some parts..
Old 01-01-2008, 09:38 PM
Yes, it was a lose gound wire from the battery to the tranny. The wire was on the stud but the nut was not tighten, at the tranny housing.
The car is a 1999 Chevy Lumina Sedan.
Old 01-02-2008, 10:20 AM
it is all too common that when we pay large amounts for labor this is how the work gets done. whenever you have work done, check vehicle out especially the areas they were working on. good luck
