Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 12-29-2007, 07:04 PM
Earlsfat's Avatar
Earlsfat Earlsfat is offline
Cheesesteakoholic
Hooking up Carb - Fuel line question...
Holley 800 double pumper on a Mark IV 454.
Fuel line from regulator has 1/2" INSIDE diameter (barb fitting). All the fuel rails on Summit and Jegs are 3/8" barb fitting --- so I'd have a 1/2" barb fitting on one end and a 3/8" barb fitting on the other - doesn't seem to work to me, don't like the 1/8" gap deal. I also don't feel like dumping $150+ for a fancy 1/2" line.
Would there be any problems coming off the regulator with ... say... size 10AN braided line - to a y block - to (2) size 8AN braided lines to the carb inlets? For example use one of these - http://www.jegs.com/webapp/wcs/store...0002_342498_-1
Any issues using those size lines / y-block?
Cheesesteak..... It does a body good.
"All you want to talk about is money, let's talk about love, and sex... forget love, let's just talk about sex. "
Old 12-29-2007, 07:37 PM
G.A.S. G.A.S. is offline
Re: Hooking up Carb - Fuel line question...
If your fuel pressure is steady, you should have no problem.
Old 12-29-2007, 11:01 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
yea, you'd be fine, I have 6AN fuel lines on mine.
