| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Shaft play
i was Just wondering how much side to side turbo compressor shaft play you guys deem acceptable. I got my 18g and I tested it and I can move it side to side a bit I'm guessing a bout 5mm. I know the real answer is its only a problem when it starts scraping against the compressor housing but what I want to know is if theres a general agreement on how much is too much.
thanks in advance.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Re: Shaft play
I dont think mine moves more than 2mm or so. 5mm is a good bit of play, sounds like the turbo will be needing a rebuild pretty soon in the future. I would expect it to smoke some also.
98 Eclipse GS Turbo Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio 1981 Chevy Scottsdale 1987 Nissan 300zx - Chump Car 2001 BMW 325i - DD |
Re: Shaft play
Didn't you just get that turbo Steviek?
Re: Shaft play
Yes I belive he got it about a week ago
Re: Shaft play
Awwww dude. Yeah, it should barely click back and forth man. When I had mine out I didnt measure it but it was I'd say that it was for sure no more than 1-2mm.
Garrett, sounds like you and me need to go to Minot and do work. |
Re: Shaft play
Re: Shaft play
Actually its not as bad as I thought. I think I was just over paranoid having never bought a used one before. I got 2 unbiased opinions who judged it to be no more than 2mm. I tried to measure but its just too difficult with such small increments. I think it should be ok. I'm not going to put it on till it warms up a bit. Working on the car in the cold is a bitch as I'm sure most of you know. I will update you when I get some real driving with it.
One thing I will be able to tell for sure is if I'm making any more airflow. As I sift through my logs the most I have ever really pushed is 39.2lbs/min. I'm hoping for a realistic 42 but would be estatic if I could make 45. Only logs and time will tell.
Re: Shaft play
Do you have a way of taking a vid?
Re: Shaft play
nah my camera is broke only records sound :@
Re: Shaft play
sweet! 18g! wanna see a before and after log with link...
Re: Shaft play
It's amazing how much thrust play a turbo can have and still "work." Only problem is once the shaft play is "bad," it continues to wear itself out at a good rate until it's gone. Glad to hear yours turned out ok.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
