| Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
911 Wont Start!!
i have a 89 gt that has 222,000 miles on it but runs mint it started when it died in the parking lot 1 mile from my house i just started clicking so i replaced the starter and it turned right on the next day the same so i again replaced the started then coming home i blew a spark plug so it was missing and stalled and kept cranking w/o keys so i disconected the battery and everytime i connected it it cranked so i replaced the starter once again and now there is nothing everything has power but no response when i turn the key light dont dim nothing i also replace the relay and the coil and the grounds look good ?? does anyone know what it can be your help will be greatly appreciated
Re: 911 Wont Start!!
Your solenoid sounds like it is screwed. Pick up a new one and see what happens. It is on the driver side fenderwell.
The truck 07 F-350 CC Dually Stroked
Yep. I had the same "continuous cranking" problem with my '87. Solenoid was bad.
1969 Cougar 357w & TKO - 475hp |
yeah i changed that sorry i forgot to mention that i have changed the relay and the coil and the spark plugs are about a month old
The switch may be bad. The plastic is bad to melt and the wires can touch where they are not supposed to. This is a problem for late 80's - 90's Fords. I had to replacw the switch on my '87 as well. If the key wasn't in just the right position it would keep cranking also.
hey guys thanks for the help i found out that its the relay they sent me a bad one because the car fires up when you pop the clutch
