Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 12-29-2007, 09:39 AM
Sigma6 Sigma6 is offline
Half shaft replacement
What has been your experience replacing half shafts? Mine really need them replaced. Book seens to say you must almost remove the entire front end. Is that true?
2007 Chevrolet Silverado
1997 Izuzu Rodeo LS 4WD
Old 12-29-2007, 11:35 AM
Cat Fuzz Cat Fuzz is offline
Re: Half shaft replacement
No. The inner cv boot must be removed on the big end and a large clip removed from the inside to pull the axle out. The inner CV joint race or cup stays in the truck with the differential.
Old 01-05-2008, 07:03 PM
egc519mzl egc519mzl is offline
You only need another hand to loosen the upper ball joint. I used this link as my guide http://www.4x4wire.com/isuzu/tech/CVboots/
02 Ford Focus @ 306K
97 G Voyager 3.3L V6 @ 122K. Trans leak fixed 5/2007
94 Jeep G Cherokee Laredo 5.2L V8 @ 159K re-fixed transfer case
last update : 01/23/2013
Old 03-18-2008, 03:47 AM
poo 95 rodeo poo 95 rodeo is offline
will this work if the cv axle outer needs to be comleatly replaced. my balls a pited and the cage hahahah. if so who do i find just the replacment parts if possible. also changed out uper ball joint and the upper control arm would not move up unless i loosend the two bolts that they ad shims to aline the front wheels. my rodeo has a production date nov. 94 any help much apresh
Old 03-21-2008, 11:35 PM
Yes it will work. The write up is for the removal of the half-shaft axle (has an inner and outer cv joint). If you couldn't find it in local auto stores, you can check www.rockauto.com.
Good luck!
Old 03-26-2008, 01:16 PM
Jepiza Jepiza is offline
you can get much information about that..http://www.fastcar.freehostia.com/ca...placement.html
