Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 12-29-2007, 08:29 AM
tahuya_eagle tahuya_eagle is offline
89 Sierra 4x4 inoperable
the lights in console fail to light up when i put 89 2500 in 4H or 4L. I checked fuse it appeared good but I replaced the 25 amp fuse anyhow. Is there another fuse or something that controls the 4 wheel drive.
Old 12-29-2007, 08:37 AM
G.A.S. G.A.S. is offline
Re: 89 Sierra 4x4 inoperable
Is it just that the lights wont light or is this not going into 4wheel drive?
Old 12-29-2007, 08:59 AM
Z15's Avatar
Z15 Z15 is offline
The front axle actuator is known to be a problem in these models. Have you noticed a long delay in engagement before this?
There is a new part to solve this problem, check with a GM dealer. It requires a new wire harness also. The original actuator needs to heat up a gas to make the plunger move to engage the front axle. Over time its just get weak and can not longer move it. The new one is electical and is instantaneous.
Check into that, its a well known problem from 88 to circa 1996.
Mike
2010 GMC Sierra SLT E. Cab Z71 All Terrain
2009 Cadillac CTS4 3.6L AWD Performance Sedan
Old 12-29-2007, 09:00 AM
The 4 wheel drive does not work, last year got a new transmission and had one of front axles replaced so I would think mechanically it is good. I do not use the 4 wheel often so do not know how long it not functioned.
