Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 12-28-2007, 05:16 PM
kyleXaltima kyleXaltima is offline
Send a message via AIM to kyleXaltima
Cool nissan altima door
aye soo i have a nissan altima 93 gxe i love the car to death but..one day i went to pick up my mom and i closed my door and now it wont open up the lock wont even unlock all the way its like something is holding it back but i have no idea what to do i called a locksmith and he sai d he dosent no what to do beacuse he cant get in side the door and my car is a stick and i dont wana climb in and accdently fall on it haha some one plz help thanx
Old 12-28-2007, 06:13 PM
RaeRae1's Avatar
RaeRae1 RaeRae1 is offline
Send a message via AIM to RaeRae1
Re: nissan altima door
hmmm... I assume you have tried muscling it from the inside while you have the handle pulled?
The only next step I would follow is to try to take off the door panel from the inside so that you can perhaps see what is binding in the door or if there is a broken part. The door panels typically are held on with clips (wish I could show you a picture). These clips are around the outside edge of the panel inset about 1/2 inch. try to get a butter knife or other thin object between the door and the panel and pry the clips loose. This can be a bit tricky so take caution not to brake your window. Once you understand how the clips work it is a piece of cake and you can remove the rest of the panel. Other than that, I am not sure what other course of action there may be.
One other thing did come to mind.... does the lock appear to work? In other words, if you unlock it with the key does the internal lock switch move to lock/unlock position?
Blessed are the cracked ones, for they are the ones that let in the light.
Originally Posted by 72chevelleOhio
Your cheer-mobile needs a flat tire.
Old 12-28-2007, 06:29 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
I don't think you can take the door panel with the door shut. Is the window up or down? If its up have a buddy kick the door itslef from inside the car while you hold the handle up. Try taking the inside trim off that mates with the door handle, usually on screw, and see what you can find. Good Luck
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 12-28-2007, 06:33 PM
RaeRae1's Avatar
Good point, it may be impossible to get to with the door closed.
Old 12-28-2007, 06:38 PM
JoeShmoe's Avatar
I'd say kick it open. My guess is that something got disconnected from the latch, so if it was in the lock position its not gonna give. Try what I suggested on the door handle.
