98 c1500 atarting problem
hey guys im new to chevysand i swaped out a motor in a 98 c1500 with the 4.3L i got everything all dialed in and when I turn the key in the on position all the sensor and fuel pump turn on but when I go to turn the truck over theres nothing no starter click nothing. So i checked all the fuses relays and my wiring all of it is in the correct spot but when I was checking the number 8 fuse (crank) ground it out and the truck starts fine and purrs like a kitten. the security light stays on when i ground out the number 8 fuse any ideas on how to remedy this problem or if anyone can tell me what the problem could be? thanks jeff
Re: 98 c1500 atarting problem
probably security system is not allowing the fuel injectors to operate
in which is what the security system in these years disabled when there was a lack of code sent from the ign key switch to the ECM if it is the kind without the chip in the key then you can try what i had to do to the 98 achieva we did with passlock no chip in the key security system i cut the black/yellow wire coming out of the ign lock switch snipped it, in the column bene perfect ever since after trying everything ot no avail including: having the instrument cluster rebuilt twice replacing the key switch twice dealer three times ended up not being repairable very common issue with the late 90s security systems in GM vehicles if the injectors are not firing when cranking then that is what's wrong disable it sometimes restting the security works for a little while if the lighty is flashing then leave the ign key in the run position with dash lights on for about 15 minutes, or until the light stops flashing then start it up this resets the security
I also am user fastr68 here- Randy -'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee, |
